Yancka
link the PIO with Sheet Layer
Is there a way to establish a link in PIO to Sheet Layer specified by mouse click, retrieve the name of SL, display the part of the name in PIO as a text and later, in case the SL gets renamed, to have the text in PIO updated too?
The pio would have to be reset somehow, either manually or by some other explicit method, because the pio normally does not get an event when a sheet layer is re-named.
Edited by Frank Brault
Idea for resetting would be a menu command like:
PROCEDURE ResetPIOs;
VAR
Criteria :STRING;
PROCEDURE ResetMyPIOs(h :HANDLE);
BEGIN
ResetObject(h);
END;
BEGIN
Criteria:=ConCat('(INSYMBOL & INOBJECT  & (PON=',Chr(39),'Name Of My Custom PIO',Chr(39),'))');
ForEachObject(ResetMyPIOs, Criteria);
END;
RUN(ResetPIOs);
What's the way you can make a link from PIO to any object? My case - to Sheet Layer, other case might be to SL Viewport?
By mouse click:
FUNCTION PickObject(pX,pY:REAL): HANDLE;
PROCEDURE ForEachObjectAtPoint(actionFunc:PROCEDURE; objOptions:INTEGER; travOptions:INTEGER; locX,locY:REAL; pickRadius:REAL);
By name:
FUNCTION GetObject(name:STRING): HANDLE;
...the pio normally does not get an event when a sheet layer is re-named.
Umm, and is there some "non-normal" way to deal with PIOs and make them event sensitive?
A PIO cannot get events from other objects. Only certain events within the PIO can be called.
Rather than renaming directly, you can write a script that will rename the SL and also update the affected PIOs
