GioPet
Tools to set Class/Layer Visibility of a selected object
Here are the scripts for some simple tools to turn On/off a layer/class visibility by clicking on an object, or to set them as Active layer/class, or to turn off all the others.
I was scripting these procedures to use them inside the script for one plugin, but I thought they could be useful also individual procedures.
See the attached Plug-ins, the scripts on the following links:
Hide the Layer of s Selected Object:
http://pastebin.com/spkutw5t
Hide the Class of a Selected Object:
http://pastebin.com/PG3myeWF
Set as Active the Layer of a Selected Object:
http://pastebin.com/bBKiN6Z8
Set as Active the Class of a Selected Object:
http://pastebin.com/9AnTzBsa
Gio
Hello Gio, great resource, i was searching for this and you decided to post it. Thx very much :)
i am an newbie at vectorscript but i am trying to change your script so that when the class is allready "isolated" , after you call the command it will un-isolate everything.
But its not working the way i script it. can you help me ?
PROCEDURE SetObjectClass;
VAR
h : HANDLE;
Active_class : STRING;
x, y :REAL;
BEGIN
IF SetClassOptions<>1 THEN BEGIN
GetPt(x, y);
h := PickObject(x, y);
IF h<>NIL THEN BEGIN
Active_class:= GetClass(h);
NameClass(Active_Class);
SetClassOptions(1);
SetTool(-240);
END;
ELSE BEGIN
SetClassOptions(5);
SetTool(-240)
END;
END;
END;
Run(SetObjectClass);
Edited by orlando Teixeira
Hi Orlando,
In an IF THEN ELSE statement, you cannot have a semi-colon between END and ELSE. A semi-colon there tells the compiler that your IF statement ends after the THEN clause. The ELSE should be kicking an error. Use a semi-colon only after the last END.
Use this format:
IF ( ) THEN begin
end
ELSE begin
end;
I haven't run your script, so I cannot comment further.
Happy scripting,
Raymond
Hi Orlando.
Great Idea!
THis Works out:
Introduce the var Class_Options to use the GetClassOptions command.
VAR
h : HANDLE;
Active_class :STRING;
x, y :REAL;
Class_Options :Integer;
BEGIN
GetPt(x, y);
Class_Options:=GetClassOptions;
IF Class_Options<>1 Then Begin
SetClassOptions(1);
SetTool(-240);
End else
SetClassOptions(5);
SetTool(-240);
End;
END;
Edited by Gio Pet
Hello Mulling and Gio , cant it be automatic ?
like this:
1)see if classoptions is 1
2)and if it is then changes it to 5 and ignores the rest of the script...
this is what i was trying to do but failed at if then else statement lol
..that's what the last script i posted does..
IF Class_Options <>1
End else
SetClassOptions(5);
SetTool(-240);
End;
Edited by Gio Pet
yes i saw it but what script allways asks to select an object.
cant he first GetClassOptions
and if the result is 1 then he changes to 5 ?
thx
I See!! you want this to work without object selection!
then you only need this..
VAR
BEGIN
SetClassOptions(1);
SetTool(-240);
End else
SetClassOptions(5);
SetTool(-240);
End;
END;
more like: but thats it
thz very very much :)))
VAR
h : HANDLE;
x, y :REAL;
BEGIN
GetPt(x, y);
SetClassOptions(1);
SetTool(-240);
End else
SetClassOptions(5);
SetTool(-240);
End;
END;
THis is more like it:
VAR
h :HANDLE;
x, y :REAL;
Active_class :String;
BEGIN
GetPt(x, y);
SetClassOptions(1);
SetTool(-240);
End else
SetClassOptions(5);
SetTool(-240);
END;
I wonder if this would be more useful when it was switching the Visibility of the Classes from Visible to invisible...
thx , i will try it whenever i arrive at work.
well now thats what i was looking for:
sometimes it is handy to turn off all the classes except one. its usefull even when you are trying to copy something, this way i do not have to use selection by class anymore :))))
perhaps one of this days i will have the time to study vectorscrit he!he!he!
indeed its allways very usefull
Thx againg for the help
