scottmoore Posted June 23, 2010 Share Posted June 23, 2010 Greetings. I have just run into a snapping issue of some sort that I can't seem to rectify. My assumption is that I have inadvertently set some preference that I cannot find to disable. What is happening is that my smart cursor snapping functionality seems to have disappeared. No manner of choosing constraints or snaps seem to rectify the problem. When using the 2D selection tool, my cursor turns from black to white and two tiny red lines appear to the top left of it whenever I hover over a selectable item. The cursor no longer turns into a cross hair to allow selection. The item will highlight for selection and I can manipulate the item, however, I cannot snap to it. When I choose a scalable selection tool option, I do get the diagonal cursor but that is all. It seems to me that I have seen this or read about this before, but cannot seem to place it. I have rebooted the application and restarted the computer as well. Any thoughts? Quote Link to comment
Yoginathaswami Posted June 24, 2010 Share Posted June 24, 2010 (edited) Check your settings in Menu>Vectorworks>Preferences>Interactive tab... Also you can check your setting in the Snapping Palette (Command+Shift+C) Double click on any one of the item in the palette, you can get to the settings. Nothing works might want to reset it. Edited June 24, 2010 by Yoginathaswami Quote Link to comment
scottmoore Posted June 24, 2010 Author Share Posted June 24, 2010 Yoginathaswami, Thank you for your reply. You were correct, in my smart cursor settings, everything had been unchecked. I have been a VW user since MiniCAD 7 and have never had this happen before. Any idea what I may have done to deselect those options? Is there some keyboard shortcut that I may have hit by accident? I certainly appreciate your reply. Quote Link to comment
Yoginathaswami Posted June 24, 2010 Share Posted June 24, 2010 Aloha, Scott: I am very sure there are keys that we are accidentally pressing. I never figured it out. I faced the similar issue couple times and resetting the pref. resolved it. Perhaps, one of our wonderful Moderators can give us a hint... Quote Link to comment
