alfresco Posted June 21, 2010 Share Posted June 21, 2010 I am developing an object with different faces. As I develope the object I need to change views Ie. front to back etc. Can I maintain the object in one place on the page as I change views without having to scoll and find the object? Thanks Quote Link to comment
mar schrammeyer Posted June 21, 2010 Share Posted June 21, 2010 Set your different views and save as saved views Quote Link to comment
Pat Stanford Posted June 21, 2010 Share Posted June 21, 2010 Do you have the "Center on objects after view change" option turned on in the VW Preferences: Display pane? The only other way to keep is relatively centered is to have the object you are interested in located a the 0,0 point of the drawing. Quote Link to comment
