New Layer, New Class shortcut
I know there are other ways of achieving this - I just wondered if it was available as a shortcut, or could be.
eg there are at least 3 ways of moving to the next/previous layer previous/next class etc including keyboard shortcuts. Same for previous View /Next View.
For some of my work it fits my workflow to work from a blank document rather than a fully developed template and add layers & classes as needed : a keyboard shortcut would be helpful.
Thanks for the Quickkeys tip I'll look into that it sounds like it might provide an answer.
You could write a very short Vectorscript and put that into a Menu procedure and than put that into a workspace.
This will do the new layer:
Procedure New_Layer;
Var
  H1   :Handle;
  S1   :String;
Begin
  S1:=StrDialog('Enter Name for New Layer:','New_Layer');
  If S1<>'' then
    Layer(S1)
  else
    AlrtDialog('You can not use that name for a layer');
End;
Run(New_Layer);
And this will do the new class
Procedure New_Class;
Var
  H1   :Handle;
  S1   :String;
Begin
  S1:=StrDialog('Enter Name for New Class:','New_Class');
  If S1<>'' then
    NameClass(S1)
  else
    AlrtDialog('You can not use that name for a class');
End;
Run(New_Class);
Go into the Vectroscript Plugin Editor and create a new Menu Command. Paste the above into the Script pane.
Then edit your workspace and assign a keyboard shortcut.
Edited by Pat Stanford
  • 8 years later...
  • 1 year later...
  • 11 months later...
I have made those script into menu commands and it it very usefull.
I also made one to activate Design Layer-1.
Layer('Design Layer-1');
I have problem making it work when I am on a sheet layer and I run the script;
I get into Design Layer-1 but objects on other layers don't show up if I had Shaded mode and if I had wireframe mode, they are fixed when I use the flyover tool.
@Pat Stanford would you have any clues why ?
2022-01-14-ACTIVE-LAYER-SCRIPT.vwx
It appears that switching to a Sheet Layer turns off Unified View.
Try this script instead. It switches to the design layer and then turns unified view back on.
SetPref(94,True);
The alternative is to use a Saved View instead. You can call that from a script by:
VRestore('Your View Name');
