gmm18 Posted June 18, 2010 Share Posted June 18, 2010 Don't want to debate, just want to know if anyone has a solution for importing Revit .rvt files. I have heard you can export a dwg from Revit, which could then be imported to VW, but alas, I do not own Revit, nor do I want to, so is there another way? An app for that? Quote Link to comment
Jeffrey W Ouellette Posted June 18, 2010 Share Posted June 18, 2010 .rvt is a proprietary format of Autodesk. As far as I know, NO other application reads/writes/imports/exports .rvt directly (Navisworks? it is an Autodesk product also). I believe any interaction with other applications native formats must occur through plug-ins that connect to Revit via a translation API, or their functionality must just be plug-ins to Revit. Autodesk has it locked down pretty hard, unlike dwg. Quote Link to comment
Bob-H Posted June 19, 2010 Share Posted June 19, 2010 (edited) I do have a one-off solution, meaning it will work for 30 days. Download Revit from Autodesk, and install it in a Windows environment. It will be fully functional during the 30 day trial - enough time to export to DWG whatever RVT files you may have. Edited June 19, 2010 by Bob-H Quote Link to comment
