Artistic Render
Howdy gents, i want to do a high quality artistic render to put on a website but whenever I do the render the lines appear very thick, ive checked the thickness of them in the render options and there set to the minimum? Also if i increase the dpi the render just appears as a final quality render and not an artistic render?
Which Artistic render are you using? Have you tried increasing the scale?
I expect you are exporting your scene as an image.
You will find the Tool Sets:Render Bitmap tool very useful for this.
You can change the ppi and adjust the render settings and use it to test a small portion of your render. Once happy with the result you then Render Bitmap the entire scene copy the result and paste into Photoshop etc before saving for web.
