Andrew Davies Posted June 12, 2010 Share Posted June 12, 2010 Hi - Am using VW2010 with Spotlight and Renderworks. I have a drawing with approx 20 Sheet layers - some with several viewports. Is there a way of automatically creating a list of drawing sheets with their latest revision numbers etc ? A drawing schedule I would call it but not sure if that's the proper name. Thanks, Andrew Quote Link to comment
michaelk Posted June 12, 2010 Share Posted June 12, 2010 Andrew There is in Architect, but I don't think it's in any other module. It uses data from the title block to generate a report. That's one of those Architect only features that I wish was in Spotlight. If you use title blocks you could probably make your own report. I just use a worksheet. Quote Link to comment
Andrew Davies Posted June 13, 2010 Author Share Posted June 13, 2010 Many thanks Michael Am hoping I can do this without Architect - so will investigate Speadsheetz / reports. Should be quite a simple thing really - just want a list of all drawings along with - title - latest revision letter & description if possible - date I have all this information in the title block so may be able to reference it somehow. Best wishes Andrew Quote Link to comment
michaelk Posted June 14, 2010 Share Posted June 14, 2010 Andrew Here's a simple drawing list. I'm not sure how to get the revision data. There is no record format for the revision data. The title block PIO has settings for the existence and position of the revision block, but no revision data. I'm sure someone will know how to find it. hth michaelk Quote Link to comment
Andrew Davies Posted June 14, 2010 Author Share Posted June 14, 2010 That's wonderful - thank you Michael ! Just fiddling about trying to get to work in my drawing now. Thanks again, Andrew Quote Link to comment
Andrew Davies Posted June 14, 2010 Author Share Posted June 14, 2010 Got it working ! Took a bit of fiddling but I'm there no. No revision data shown in the list - that's a step too far for now, but thanks so much for your help ! Will come back to the revision data at a later date - entering it manually for now. Thanks again, Andrew Quote Link to comment
Pat Stanford Posted June 14, 2010 Share Posted June 14, 2010 The revision data is in a really had to work with format. Instead of being able to attach multiple records to the object, there is one record with multiple fields numberd sequnetially. I think it goes up to 20, but it has been a while since I worked with it. Generally, the format makes it really hard, nearly impossible, to do anything useful with the revision data in a worksheet. Quote Link to comment
michaelk Posted June 15, 2010 Share Posted June 15, 2010 Pat I was surprised that your magic script (which I use all the time) doesn't return anything about the revision data. And there doesn't seem to be a revision record format created when using revision data. It must be baked into the secret sauce... michaelk Quote Link to comment
Pat Stanford Posted June 15, 2010 Share Posted June 15, 2010 I can't find the revision data tonight either. The last time I really took a close look at this was either VW2008 or maybe even 12.5. At that time there was a hidden record attached to the drawing border object with fields like Rev_1, Rev_2, Descrip_1, Descrip_2, etc. I think they went up to 50, but I am not sure. Made it very hard to work with as there is little in VS or Worksheets to allow the munging/combining of different fields with similar names. In VW2010, I can't find the revision record at all. It must be there somewhere, but I am not seeing it. Ok, I just found it. The record format does not exist and is not attached until you actually put revision data in. Take a document with a sheet border and title block and enter some revision data. Take the Magic Script and change the second line after the initial begin with: H2:=GetRecord(H1,1); It should have been something like H2:=GetRecord(H1,NumRecords(H1)); Run the script. You should get a worksheet showing all of the revision data record fields. Dashes instead of underscores. 4 field types duplicated 50 times for a total of 200 fields. Pretty useless data format for trying to do anything. Quote Link to comment
Andrew Davies Posted June 16, 2010 Author Share Posted June 16, 2010 Hi Pat & Michael - I did a work around which was just to add a Rev record format to a title block. As long as I remember to update this when I update revisions it works fine. Would love to get it seamless - would I be able to get hold of the "magic script" ??! Thanks Andrew Quote Link to comment
michaelk Posted June 16, 2010 Share Posted June 16, 2010 Pat's magic script creates a worksheet that lists all the possible fields from a PIO object or symbol with attached records. Just select an object and run the script. He's been generous enough to post it in the Vectorworks Resource Share - VECTORSCRIPT forum: http://techboard.nemetschek.net/ubbthreads.php?ubb=showflat&Number=108487#Post108487 It's a very valuable tool. I use it all the time. Quote Link to comment
Decoyman Posted February 23, 2011 Share Posted February 23, 2011 I tried this and got a list of Issue Data. Try changing the line to: H2:=GetRecord(H1,2); For some reason this doesn't list the revision numbers. Does anyone know how to extract the data? Rob Quote Link to comment
VincentCuclair Posted February 23, 2011 Share Posted February 23, 2011 (edited) Now we're at it, can someone please explain what the function is of Issue Data. I'm used to the Dutch and Swedish ways and am not sure what the equivalent is. We have Sheet dates/data and Revision dates/data but why the Issue dates/data? I mean having both sheet dates and issue dates, doesn't that just confuse things? Edited February 23, 2011 by Vincent C Quote Link to comment
schsch Posted January 11, 2019 Share Posted January 11, 2019 hi there, i know, its a long time... but I m interested in this magic scirpt too;) I try to make a Plan-Issue list. Is it possible to link text to the record format of 'drawing sheet - general' __last issue` ?? I tried it, but it seems, that there is no access to the drawing sheet - general plugin Quote Link to comment
