also how to equally divide a line.
another ?
- if i am looking to find equally divided sections (maybe on a line) in cad i just draw a line then do teh divide command, enter the amount of sections then bam, the line divides into the segments. ---useful in finding spacing of center lines w/o having to crunch out the numbers.
how might i do something simliar in VW ?
thanks again!
If what you really want is equally spaced centerlines filling an allotted space, there's a neater way to do that:
- draw a centerline
- while it's still selected, group it
- go into the group by double-clicking on it
- offset or array the centerline to get the number of centerlines you want (the offset distance doesn't matter, just so they're all offset the same)
- exit the group by clicking outside it
- drag-stretch the group to fit into the allotted space.
And maybe drag-stretch it in the other axis to set the length of all the centerlines.
Line Into Segments is good if what you really want is a line divided into segments.
