Yancka Posted June 5, 2010 Share Posted June 5, 2010 I'm trying to run Duplicate Along Path command, but this is more comprehensive issue regarding dialog window control in general. My script assumes 2 objects (1 of them is polygon) are selected and I'd like to apply (I didn't find appropriate VS function): DoMenuTextByName('Duplicate Along Path',0); Then I want to retrieve curve length and set duplicate placement as integer which is curve length rounded up, then hit OK. Is it possible with script? The main question is how to set duplicate placement settings as I want and hitting OK programmatically in active dialog window. Quote Link to comment
