AutoCAD to Vectorworks
Hi Ozzie that's perfect. I had an email from a forum member saying to use the wall tool, when I use this and change from plan view to isometric the wall is 3D which I don't want. They then said to use the rectangle tool. Would you agree?
Hi its me again :)
I have read that in vectorworks you should draw with blocks, so use the rectangle tool instead of the line tool.
Yes you should. much quicker and easier to draw and edit with Surfaces.
Anyway I have ignored this advice and used the line tool to draw a wall with a few 90 degree angles in it. I would like to fill the wall with hatch or pattern but cannot.
Do I need to create a type of polyline to do this?
Note also: If you have a series of objects which enclose a space you nominate the specific boundaries and choose Modify> Combine into Surface, or use the Paint Bucket mode of the Polygon tool to make a new surface to fill
You could try the Double-Line Polygon tool or perhaps the wall tool with no height
With regard to rectangles as you mention in one of your previous posts - try this
Draw a rectangle and then another with say a corner over the top of the first one
Select the last one you drew first and then the first one you drew and go Modify Add Surface - play with the other Surface commands - Clip, Intersect and Combine
This works with Circles, Polylines, the Freehand tool etc
Remember there is a stacking order in VW with the last object drawn being on top
To see this draw a rectangle and give it a color fill - draw a circle and give it a different color fill and have it a little over the top of the rectangle
Right click the circle and Modify/Send/Send to Back
Play with the Modify Send commands
  • 1 month later...
Hi again I haven't used VW for a couple of weeks now but remembered most of what you guys have shown me which is great and can reasonably competently do a working drawing although I am slower than when using AutoCAD.
Where would you guys go next? The 3D walls etc confuse the hell out of me as the model space appears so different to that of sketchUp.
Are you all using custom keyboard shortcuts and s this done in the workspace editor then save as your default template?
3-D walls can be daunting at first but take a few moments to play with some simple floor plans made with the Walls Tool. One important thing to consider is the difference between LAYERS & CLASSES. As Classes are more like AutoCad Layers - use them for graphic info, Layers are more like the Layers of Mylar we used to use to draw on - so a Layer can occupy the same 2-D space, but will be separated in 3-D by whatever value you give to the Layer.
The wall tool can be selected to accept the THICKNESS or delta Z value of a Layer. As long as one sets the Layer's Z value correctly the walls will stack properly.
Try this:
- Create four Layers each with a delta Z of 3M or 10'
- Leave one Layer with a Z value of 0 change the rest to multiples of 3M or 10' (ie 3,6,9)
- Draw a simple floor plan with the wall tool & check the box on the IOP "Link wall height to layer delta Z"
- Select all walls, Duplicate, then move these duplicates to one of the other Layers.
- Repete this two more times to fill the other two layers.
Now create a Viewport & have all three layers active, & change the View in the OIP to Right Isometric & there is your building. If you play with that technique, you should get the hang of the thing in no time.
  • 1 month later...
Hi thought I would continue using this topic rather than start another.
I have been asked to plot some bollards on a large area of land, would the 2D locus tool be suitable for this as all I need is a cross to indicate the position?
Also when I click on the eye icon in layers nothing happens?? as it would in adobe.
last but not least when i use the dimension tool to try and figure out an angle I get two squares and no measurement. what have i done? I'm working on a second layer.
Rather than combining the two layers why not create a Viewport which contains both and place this on your Sheet Layer? Sheet Layers can have multiple Viewports at various scales, projections & renderings.
View>Create Viewport
You can then scale the Viewport through the Object Info Palette to fit your paper exactly as needed.
The inclusion of a Drawing Label has the happy property of displaying the active scale of the viewport automatically.
Dims/Notes Palette: Drawing label
