Yoginathaswami Posted June 3, 2010 Share Posted June 3, 2010 Aloha Is there a way to make the other ungrouped roofs visible while editing one segment? It would make the aligning process easier... I have the preferences set to "show other objects while in editing modes" checked. I have to come out editing mode in order to see if I got it right... Thanks Quote Link to comment
bcd Posted June 5, 2010 Share Posted June 5, 2010 Excellent question I'd say. I usually draw lines / loci in Top/plan view representing the relevant plane breaks etc.that I need. Then: Cut Edit roof surface Paste in place. (delete when finished with them) Unlike Symbols the roof edit mode respects the global coordinates so Paste in place will work. A more detailled workaround would be select all roofs Modify>Convert Copy to Lines Copy Edit Roof face - Paste in place. (this could also be done with a symbol and and insertion point set at 0,0) Of course - back to your question - having the other roofs visible and snaptoable while in Edit mode would make these workarounds obselete. Quote Link to comment
CipesDesign Posted June 5, 2010 Share Posted June 5, 2010 It is also possible to use Add Surface and Clip Surface directly on a Roof Face (or a Floor or any other hybrid objects). Just draw the polygon you wish to add/clip, select the roof face and the poly, and add/clip away... Quote Link to comment
bcd Posted June 5, 2010 Share Posted June 5, 2010 (edited) Hey Peter, this is fantastic. I didn't know this! Great feature & timesaver. Almost makes the edit roof mode redundant if the 2d can be edited directly on the object. It seems there's also a very useful application where it comes to walls where it invokes wrapping and wall recesses / breaks and projections. Wow! What other treasures lie within? This deserves a study session of it's own. Thanks Peter. Edited June 5, 2010 by bcd Quote Link to comment
Yoginathaswami Posted June 6, 2010 Author Share Posted June 6, 2010 Thank you bcd?for loci and line idea and Peter that is a brilliant idea! Quote Link to comment
CipesDesign Posted June 6, 2010 Share Posted June 6, 2010 This has been possible for a few versions. It also works on floors... Quote Link to comment
Peter Eichel Posted June 6, 2010 Share Posted June 6, 2010 You don't need to ungroup a roof, use "CONTROL C" to make a copy of it and "CONTROL C" to move it a distance so you can edit it separately from the original. Ungroup the copy and delete the roof planes. You now have the gable walls left to add windows too or whatever. When your finished move the walls back the opposite distance which will put them in exactly the right place. Turn off the gable walls in the original and there you have it. You still have your original roof object which is preferable to one that has been ungrouped. Quote Link to comment
Peter Eichel Posted June 6, 2010 Share Posted June 6, 2010 Error! My previous reply states using "CONTROL C" to move an object, it should read use "CONTROL M" to move an object. Sorry. Quote Link to comment
