Speedy Gonzales Posted December 13, 2001 Share Posted December 13, 2001 I just received an email from Apple (promotional) that Suitcase 10 supports Type 1 and multiple master fonts in OS 9.x and X. This may the $129.95 answer (?) Anyone know anything more about this program or a workaround? (I used Suitcase before I switched to ATM because Suitcase had a number of extension conflicts I couldn't resolve.) Quote Link to comment
FRED JOHNSON Posted December 13, 2001 Share Posted December 13, 2001 quote: Originally posted by CEA: Thank you for your promt reply.Unfortunately, this font does require ATM. We are using the font with VW 9.0.1 and MAC OS9.1 and have had no problems (it also worked well with VW8). Rotated and vertical text print well on our HP488CA. I am concerned that we will have a problem if we switch to OSX. I have read the previous topic regarding fonts, but I am still uncertain whether this font will work or or not with OSX. Thanks for your help. Quote Link to comment
FRED JOHNSON Posted December 13, 2001 Share Posted December 13, 2001 quote: Originally posted by CEA: Thank you for your promt reply.Unfortunately, this font does require ATM. We are using the font with VW 9.0.1 and MAC OS9.1 and have had no problems (it also worked well with VW8). Rotated and vertical text print well on our HP488CA. I am concerned that we will have a problem if we switch to OSX. I have read the previous topic regarding fonts, but I am still uncertain whether this font will work or or not with OSX. Thanks for your help. I use Graphite for all my drawings but it is the true type version, which is available all over the place. Must you have postscript? Quote Link to comment
Speedy Gonzales Posted December 14, 2001 Share Posted December 14, 2001 Thanks for the input and information. I guess I don't know the answer to your question? I assume all TrueType print in the Mac OS 9.x works just like the PostScript version, especially if you have ATM and its anti-aliasing on. In OS X, the anti-aliasing is built in. So am I to understand that their is a TrueType version of Graphite available as shareware or purchase and that it will work with OS X, VWA 9.5, laser and inkjet printer, and plotters (HP455CA)? Please clarify. If Graphite is available and it does work with this configuration, where should we all go and get the font? Quote Link to comment
