charding Posted June 2, 2010 Share Posted June 2, 2010 Hi all, In the past I could move individual fields of the label legend around on a per instrument basis. However now the fields and instrument symbol all seem to be "grouped" together and I can only move them as one unit. VW 2010 SP3 Thanks, -Clay Quote Link to comment
michaelk Posted June 2, 2010 Share Posted June 2, 2010 Sounds like you may have interactive scaling disabled. Make sure the 2D Selection Tool is in "Single Object Interactive Scaling" Mode. This will make the blue handles appear on all the label legend fields. Hit Escape, then double tap the X key. Then keep tapping the U key and you will see the modes toggling through in the upper left hand corner. You want the second mode with the single set of diagonal arrows. hth michaelk Quote Link to comment
charding Posted June 2, 2010 Author Share Posted June 2, 2010 Thanks Michael, I had already checked to make sure that interactive scaling was enabled (and it was) I cycled through the modes again after your post and it began to let me move fields. Not sure what the problem was, but thanks for helping! -Clay Quote Link to comment
Vectorworks, Inc Employee klinzey Posted June 2, 2010 Vectorworks, Inc Employee Share Posted June 2, 2010 Try creating a new Label Legend and see if that fixes the problem. Quote Link to comment
Evan Drill Posted July 1, 2010 Share Posted July 1, 2010 Just wanted to throw it out there that a) I?ve always wondered what those settings did and b) that just solved the problem I?ve been trying to figure out for a week! Thanks posters Quote Link to comment
