Kevin McAllister Posted May 30, 2010 Share Posted May 30, 2010 Is there a way to properly map a texture onto a door? I have a parametric door object which I have assigned the inner/outer leaf parts to a style class. When I assign a wood texture to the class it maps onto the door as vertical lines. I did a test with the same texture and extruded rectangle which was much more successful. Thanks, Kevin Quote Link to comment
Kevin McAllister Posted May 30, 2010 Author Share Posted May 30, 2010 Ok, so I discovered part of the problem seems to be having the doors open in 3D. K Quote Link to comment
