Decoyman Posted May 28, 2010 Share Posted May 28, 2010 I am having a problem with windows in elevation. When I zoom in close to any edge of the opening I can see two lines where there should be one. They are exactly 0.254mm apart, which I think is 0.01". If I switch on either the inside or the outside trim the additional lines disappear, unless I set the dimensions of the trim to 0, in which case the rogue lines come back. Has anyone else encountered this and have any idea how to stop it? I definitely don't want any trims showing. Also, and this may be related, when I add a sill a border the same depth as the sill is added all round the window. The border doesn't appear on the plan but does in elevation. This is simply constructionally incorrect and I have no idea why it is happening. I am attaching a file which shows what I mean. You'll have to zoom in to the left hand window to see the extra border. I'm using VW 2009. Thanks. Quote Link to comment
willofmaine Posted May 29, 2010 Share Posted May 29, 2010 I only have VW 2008 and so can't open your file, but it sounds like the kind of thing that is the reason why, after schematic design, I tend to model my doors & windows from scratch. Tedious, but it makes for complete control over the results... AND, if you want to do something completely crazy like have a 6 over 9 window, you can do it (though maybe 2009/2010 have more capabilities in that regard...). Quote Link to comment
