Walkthrough
It's very cumbersome yes. There is the opportunity for a good degree of control however.
It should be called Animation from Saved View to Saved View rather than Animation along path.
All you need to do is create a series of saved views and use these to create the animation. (fiddling with the little timing window is a nuisance and you need to drop each saved view in there but the result will give you what you need)
It's a good idea to test your animation in Wireframe to be sure you're happy with it before producing the rendered result.
