Yoginathaswami Posted May 22, 2010 Share Posted May 22, 2010 Aloha, I have my Layer Options set to "Show/Snap/Modify Others"?for some reason?I can't select, modify or snap objects on another layer. This occurs only with certain VW documents not all files. Am I accidentally activating (or deactivating) something? I can force select the object using contextual menu or by the changing the layer. Any thoughts? Thanks! P.S.: I have my Classes also set to "Show/Snap/Modify Others." Quote Link to comment
Ray Libby Posted May 22, 2010 Share Posted May 22, 2010 All layer must be in Top Plan view, NOT Top view. Quote Link to comment
Yoginathaswami Posted May 22, 2010 Author Share Posted May 22, 2010 Thanks Ray! Quote Link to comment
Pat Stanford Posted May 22, 2010 Share Posted May 22, 2010 The layers must also be at the same scale. Quote Link to comment
Yoginathaswami Posted May 22, 2010 Author Share Posted May 22, 2010 Thanks Pat. I happened to have one layer in Top view and the other was in Top Plan view. But will keep this scale issue in mind. Quote Link to comment
Jonathan Pickup Posted May 23, 2010 Share Posted May 23, 2010 view on the menu bar > Align layer Views Use this command to get all the layers to the same view. If you use unified view, Vectorworks will do this for you automatically. Quote Link to comment
