I am making a 2D basic floor layout with numbered equipment racks.
I have created a symbol with an attached record to number the racks. Everything looks great in VWX and in PDF.
But when I try to export to DWG the symbol appears fine but the record that is attached to it is set at its default value. I have checked this with AC2007 even if the data is correct (the correct number appears in the data field) the displayed number is wrong. The SolidWorks eDrawings viewer displays the same issue.
I have removed any special characters and spaces from all names and fields of the record/symbol resources. But it still doesn't work.
Fawzi
Any clues ?
2 answers to this question
