EC1 Posted May 11, 2010 Share Posted May 11, 2010 This has possibly been covered on here before (I have tried havign a look but I can't find it) - is there a way to chnage the orientation of plant labels once you have placed the plants? I saw some reference to beign able to do thsi using rotated plan view, but placing new plants on a rotated plan view they still have the same orientation as my original labels? Quote Link to comment
Vectorworks, Inc Employee Tamsin Slatter Posted May 15, 2010 Vectorworks, Inc Employee Share Posted May 15, 2010 If you 2009 or later, you can use the reshape handles on the plant tags to change the orientation of the text. Unfortunately, with 2008 you cannot do this. A workaround, if you are in Rotate Plan view, is to select your plants and change the angle in the rotation field in the Object Info palette to 0. This will cause your plant tags to move, but they will be aligned to the horizontal. All the best Quote Link to comment
