Line Style by Class Bug?
Can someone else try this and see if they get the same result -
- add some custom dash styles (I cut and paste some lines from another file) and edit the order of the dash styles under File>Document Settings>Dash Styles
- choose one of the moved styles and assign it to a Class as the default By Style line type
I am seeing that while the drop down in the Class dialog shows the correct line style, the objects in that class still display the old, pre-move style (ie. the old style that was 4th down from the top, instead of the new style that is now 4th down from the top in the drop down).
Hopefully that clear enough.
Thanks,
Kevin
