MBMD Posted May 10, 2010 Share Posted May 10, 2010 In VW 2010 is there a way to convert a basic 5" wide wall with no fill into two lines without deleting doors and windows. When I ungroup the wall it makes a centerline and a filled polyline. I don't want either of these to appear. I just want the two basic lines. Is that possible? Quote Link to comment
michaelk Posted May 10, 2010 Share Posted May 10, 2010 Almost... -Select the walls. -Ungroup. Lines, polygons, doors, windows remain selected. -Shift click on the doors and windows to deselect them and leave the ungrouped geometry selected. -Modify>Convert>Convert to Lines (hidden line rendering). -On my machine this leaves the (invisible) center lines w/ a pen weight of none. -Use the Select Similar Tool w/ the preferences set to all the Pen Attributes options and delete the invisible center lines. hth Quote Link to comment
bcd Posted May 11, 2010 Share Posted May 11, 2010 (edited) Or try the polygon tool: 8 > From inner boundary mode> click within the space From outer boundary mode> Encircle the walls Select both polygons > Clip Surface, Delete. Edited May 11, 2010 by bcd Quote Link to comment
