beanus Posted May 10, 2010 Share Posted May 10, 2010 I've been using the elevation benchmark tool in view ports and I've just realised that if I move a viewport vertically the benchmark value changes, is there a way to stop this happening? Quote Link to comment
Yancka Posted May 10, 2010 Share Posted May 10, 2010 No. With built-in elevation benchmark you can only check the option to Use Control Point and then manually place it on 0 level. Quote Link to comment
Vectorworks, Inc Employee klinzey Posted May 10, 2010 Vectorworks, Inc Employee Share Posted May 10, 2010 I think this was fixed in 2010. Quote Link to comment
Yancka Posted May 10, 2010 Share Posted May 10, 2010 Oh, mine.... I already was trying to write PIO for this... can anyone with VW2010 test it an approve that it indeed works? Quote Link to comment
Ken Posted May 13, 2010 Share Posted May 13, 2010 You can "compensate" for it by adding or subtracting the Reference Elevation in the OIP. Quote Link to comment
willofmaine Posted May 18, 2010 Share Posted May 18, 2010 Why don't Elevation Benchmarks just use the file's Z=0 value? All of the design layers are set with respect to this Z=0, so it seems it would make sense for section viewports to also use this value. Buildings could be set at their real-world elevations or, alternatively, a file-wide adjustment could be used if one prefers to model their first floor at Z=0. Either way, having to explain to a client that their building is sitting higher or lower on the site than expected because the viewport was moved on the sheet is not terribly appealing... Quote Link to comment
mike m oz Posted May 19, 2010 Share Posted May 19, 2010 I agree with Will. If a Layer's Z has been defined as 98' (or 98 m) then the Elevation Benchmark object should be aware of that and in Elevation and Section Viewports automatically reflect that. Moving the Viewport around on the Sheet Layer should not affect this. Quote Link to comment
Jonathan Pickup Posted May 19, 2010 Share Posted May 19, 2010 I'm with mike and will Quote Link to comment
J Lucas Posted May 19, 2010 Share Posted May 19, 2010 That would be "Intuitive". That is what I intuitively expected the first time I used the Elevation Benchmarks. Quote Link to comment
gScott Posted June 1, 2010 Share Posted June 1, 2010 i have a symbol with all the main levels dashed, with benchmarks, all set relative to the symbol's 0,0 datum. slap that in the annotations, at the correct height relative to the model + fewer screw ups are encountered on site; only one set of levels to update + keep an eye on.. Quote Link to comment
