tamarindi Posted April 29, 2010 Share Posted April 29, 2010 In the tips&tricks Tips&Tricks movie -> tip no. 4 -> aligning roof tiles to roof with the align plane tool. However, when i try doing exactly the same i get this message: "The Align Plane tool does not work with walls or roofs. They must remain oriented relative to the active layer plane." I used the exact tools order as in the movie....: roof -> set working plane tiles -> align plane. then i get the message.... Quote Link to comment
Ken Posted April 29, 2010 Share Posted April 29, 2010 Seems to make sense to me, as those objects (roofs and walls) have parameters tied to layer geometry. It's best to use 3D symbols, extrudes or other boolean geometry as your roof tile objects to align to working plane. I must applaud the improvement of the Working Planes tool/command/palette. There are still some less-than-intuitive procedures, but it's a whole world better than before. Quote Link to comment
tamarindi Posted April 29, 2010 Author Share Posted April 29, 2010 Hi Ken, If you have seen the section in the movie (4) you can see that the demonstration is specifically regarding roof and roof tiles. But i figured out the problem: I used a hybrid symbol. and that made a conflict with the plane. As soon as deleted the 2D object it snaps perfectly to the roof object. :-))) Quote Link to comment
Jonathan Pickup Posted April 29, 2010 Share Posted April 29, 2010 here is another tip movie for working planes. Where you click on the start object is very important. Quote Link to comment
tamarindi Posted April 29, 2010 Author Share Posted April 29, 2010 Thanks Jonathan. Great help !! Quote Link to comment
Ken Posted April 29, 2010 Share Posted April 29, 2010 Tami, glad you figured it out. The non mention of a hybrid symbol in the warning message does seem inconsistent. They should at least say, "the align plane tool does not work with walls, roofs or 2D/3D symbols. They must remain oriented relative to the active layer plane." It's a minor issue, but hopefully NNA can pick this up. That Top Ten movie, as well as Jonathan's excellent tutorial, actually show the object as a group, not a roof tile symbol. Probably a group of extrudes. Many thanks to Jonathan for sharing. I always pick up tips when watching those movies! Quote Link to comment
