milocontext Posted April 29, 2010 Share Posted April 29, 2010 I am looking for a good hand drafting type of font. Any suggestions? Quote Link to comment
Ray Libby Posted April 29, 2010 Share Posted April 29, 2010 Mr Hand is what I use. http://www.will-harris.com/store-h/architect_fonts.htm Quote Link to comment
cbd Posted April 30, 2010 Share Posted April 30, 2010 I was just checking out the latest posts and noticed this one. I have been looking for a drafting font for the last year and Mr. Hand looks perfect. Thank you Ray. Quote Link to comment
Ray Libby Posted May 1, 2010 Share Posted May 1, 2010 Glad you like it, I think it looks much better than any other architectural fonts. Quote Link to comment
UrsVW Posted May 14, 2010 Share Posted May 14, 2010 Hi Ray I am new to the community board so I don't know how it really works. I have come across some of your replies to FONT problems and wondered whether you would be able to tell me the location of the fonts in VW2010. I struggle to find it. I would like to add some new ones. My email is: edelweiss@paradise.net.nz Cheers - Urs Quote Link to comment
Ray Libby Posted May 14, 2010 Share Posted May 14, 2010 Vectorworks uses system fonts, the same as most other programs. I would need to know your OS to tell you where they are. Quote Link to comment
Vectorworks, Inc Employee Tamsin Slatter Posted May 15, 2010 Vectorworks, Inc Employee Share Posted May 15, 2010 Just install as usual - then VW will be able to see the font. You can set the default using the Text menu in VW. Quote Link to comment
CipesDesign Posted May 15, 2010 Share Posted May 15, 2010 I think you need to quit and restart VW (or any other programs) in order to see the newly added fonts. Not positive, but just in case... Quote Link to comment
Ray Libby Posted May 16, 2010 Share Posted May 16, 2010 You are correct Peter, VW will need to be restarted, good catch. Quote Link to comment
preston bircher designs Posted May 18, 2010 Share Posted May 18, 2010 I am very new to Vectorworks -- and I have system fonts that i want to use. I use 'TwoByFour' http://www.fonthead.com/fonts/TwoByFour by Fonthead Design and I really like it. My question is--is there a way that i can see my font(s) while working on the drawing? Like for visual spacing, etc. All I can see is Arial--no matter what i chose in the font selection menu. Thanks! Preston Quote Link to comment
Kevin McAllister Posted May 18, 2010 Share Posted May 18, 2010 Preston, I think I know what the problem may be. Go into Vectorworks Preferences (Tools>Options>Vectorworks Preferences), click on the Display tab, and then click on the Edit Font Mappings button. If there is a list of Font Mappings, delete them. I suspect you may be mapping some fonts to Arial.... so they don't show up as themselves, but as Arial instead. Kevin Quote Link to comment
CipesDesign Posted May 18, 2010 Share Posted May 18, 2010 (edited) Hi Preston, you should be able to see your font as you type by setting it to be your default font. In order to select your choice of font as the "default" font, make sure that nothing is selected and that the cursor is of the plain 2d selection type (*not* the text cursor - which would indicate that the text tool is the active tool) and then go to the Menu>Text>Font Pulldown and select the chosen font, size and style. This will now be your default font. So when you subsequently select the text tool and begin typing, you should see your font as you go. One caveat: certain fonts tend to jump a little when exiting (or entering) the text field. This can be annoying, but it's gotten a little better over time, and will hopefully continue to improve. [EDIT: I just tried this on one of the fonts that I have seen jump. In the latest version this problem seems to be solved....] Also, as a side note, I would consider your question to be a new question and not exactly "on topic" for this particular thread. In the future it would probably be good to start a new thread when you have a new question, issue or comment. Thanks! Hope that helps, P Edited May 18, 2010 by CipesDesign Quote Link to comment
preston bircher designs Posted May 18, 2010 Share Posted May 18, 2010 Kevin: no mappings ... but it was worth the try. Peter: OK, I selected the font as my 'default' and when I type a text field on the drawing, it appears in the correct Architectural font. However, when I release (back to the 2D tool) the font reverts to Arial. I'm using Designer; Spotlight and the Lighting Postions i have noted with the correct font--but also appear to be Arial. While I've got you on the line--I have many fonts in my system. I also work with our show Graphics Design. So when I open the Text>Fonts menu--two screens of fonts appear--and no way to go past them to the rest of the alphabet of listings. Any ideas there? --- (sorry--probably should be in another thread -- but while we're in my font nightmare...) Thank you, Preston Quote Link to comment
CipesDesign Posted May 18, 2010 Share Posted May 18, 2010 Preston, that's really odd. I wonder if you have something funky in one of your installs. Not being a windows guy I think I will defer to others who be better able to diagnose this. Ray, Kevin, are you still listening?? P Quote Link to comment
Ray Libby Posted May 18, 2010 Share Posted May 18, 2010 Preston, try some different fonts and see if you get the same behavior. You may have an older or bad font. What font did you use? Where did you get it? To access fonts that are off screen in the font menu, create a text block, then use the pull down menu in the Object Info Palette to set the font that you want. That font will now be at the beginning of the font menu in the favorites and you will be able to choose it as the default. Quote Link to comment
preston bircher designs Posted May 18, 2010 Share Posted May 18, 2010 Every font I choose will 'type' in the correct font--but then when it's released, then to Arial. I did find one rogue lighting position that was helvitica--but it did the same thing. The font I want to use is "Two-By-Four" from Fonthead (http://www.fonthead.com/fonts/TwoByFour) and I purchased it from them in Jan 2010. It works in all programs--and works while "selected" in Vw2010/Spotlight. I'm totally confused! Thanx, y'all! Quote Link to comment
Ray Libby Posted May 18, 2010 Share Posted May 18, 2010 Go to Vectorworks Preferences, Display tab. Uncheck GDI+imaging and try it. Quote Link to comment
preston bircher designs Posted May 18, 2010 Share Posted May 18, 2010 MY FELLOW FLORIDIAN!!! You did it! That was the trick! It all looks absolutely correct now! Thank You! Quote Link to comment
Ray Libby Posted May 18, 2010 Share Posted May 18, 2010 Glad it works, you won't be able to use Layer transparency now though. Quote Link to comment
preston bircher designs Posted May 18, 2010 Share Posted May 18, 2010 I'm still new--havn't gotten that far yet--so when I do that'll be the next hurdle. Quote Link to comment
