Move by points
altoids
Using the move by points command, I am instructed to "use the command key to select an object". This work, unless the CAPS LOCK key is down, which prevents any object from being selected. This happens on two different OS X machines, all latest versions.
Is there a way to use the Move by Points with the caps lock down, and select an object?.
(OS X 10.6.3 VW2010 SP3)
