Yancka Posted April 21, 2010 Share Posted April 21, 2010 I'm "treading in unchartered territory" of nested PIOs. Need some help. Child PIO is "2D Quadrilateral", mother PIO is "2D Quadrilateral Assembly". Into assembly PIO I insert 2 "2D Quadrilateral" instances. The first one is rectangle. The second is square. I want to place the square besides the rectangle (I'm using HMove). For that I need to calculate the distance. I fail to get the actual distance with "MidRectWidth:=Str2Num(GetRField(MidRect,'2D Quadrilateral','Box Width'));" I'm getting only default value for 'Box Width' parameter. Meantime in schedules everything is OK and the values are correct. May be this is due to some shortcomings in overall logics of my PIOs and standard size settings? The code of "2D Quadrilateral": PROCEDURE Quadrilateral; VAR RectWidth, RectHeight :REAL; PluginHandle, PluginRecordHandle, PluginWallHandle :HANDLE; PluginName :STRING; BEGIN IF GetCustomObjectInfo(PluginName,PluginHandle,PluginRecordHandle,PluginWallHandle) THEN BEGIN RectWidth:=PBox_Width; RectHeight:=PBox_Height; {PluginHandle:=FSactLayer;} IF PCustom_size=false THEN BEGIN EnableParameter(PluginHandle,'Box Width',false); EnableParameter(PluginHandle,'Box Height',false); IF PQuadrilateral_type='Square' THEN BEGIN IF PSquare_standard_size='A1' THEN RectWidth:=350; IF PSquare_standard_size='A2' THEN RectWidth:=680; IF PSquare_standard_size='A3' THEN RectWidth:=975; END; IF PQuadrilateral_type='Rectangle' THEN BEGIN IF PRectangle_standard_size='T1' THEN BEGIN RectWidth:=350; RectHeight:=680; END; IF PRectangle_standard_size='T2' THEN BEGIN RectWidth:=680; RectHeight:=975; END; IF PRectangle_standard_size='T3' THEN BEGIN RectWidth:=975; RectHeight:=1550; END; END; END ELSE BEGIN EnableParameter(PluginHandle,'Square standard size',false); EnableParameter(PluginHandle,'Rectangle standard s',false); END; IF PQuadrilateral_type='Rectangle' THEN SetParameterVisibility(PluginHandle,'Square standard size',false) ELSE BEGIN SetParameterVisibility(PluginHandle,'Rectangle standard s',false); EnableParameter(PluginHandle,'Box Height',false); RectHeight:=RectWidth; END; SetRField(PluginHandle,'2D Quadrilateral','Box Width',Num2Str(0,RectWidth)); SetRField(PluginHandle,'2D Quadrilateral','Box Height',Num2Str(0,RectHeight)); MoveTo(-RectWidth/2,0); Rect(-RectHeight,#90,RectWidth,#0); END; END; Run(Quadrilateral); And the code of "2D Quadrilateral Assembly": PROCEDURE QuadrilateralAssembly; VAR PluginHandle, PluginRecordHandle, PluginWallHandle, MidRect, LeftSquare :HANDLE; PluginName :STRING; XOffset, MidRectWidth, LeftSquareWidth: REAL; BEGIN IF GetCustomObjectInfo(PluginName,PluginHandle,PluginRecordHandle,PluginWallHandle) THEN BEGIN MidRect:=CreateCustomObjectN('2D Quadrilateral',0,0,0,false); SetRField(MidRect,'2D Quadrilateral','Quadrilateral type','Rectangle'); SetRField(MidRect,'2D Quadrilateral','Rectangle standard s',GetRField(PluginHandle,'2D Quadrilateral Assembly','Rectangle standard s')); SetRField(MidRect,'2D Quadrilateral','Custom size','false'); LeftSquare:=CreateCustomObjectN('2D Quadrilateral',0,0,0,false); SetRField(LeftSquare,'2D Quadrilateral','Quadrilateral type','Square'); SetRField(LeftSquare,'2D Quadrilateral','Custom size','false'); MidRectWidth:=Str2Num(GetRField(MidRect,'2D Quadrilateral','Box Width')); LeftSquareWidth:=Str2Num(GetRField(LeftSquare,'2D Quadrilateral','Box Width')); XOffset:=-(MidRectWidth+LeftSquareWidth)/2; HMove(LeftSquare,XOffset,0); END; END; Run(QuadrilateralAssembly); Quote Link to comment
Miguel Barrera Posted April 21, 2010 Share Posted April 21, 2010 You cannot get values for the child pio because it has not been created yet. The mother pio needs to complete to actually create the child. Quote Link to comment
Yancka Posted April 22, 2010 Author Share Posted April 22, 2010 You cannot get values for the child pio because it has not been created yet. The mother pio needs to complete to actually create the child. Sounds quite reasonable. Thanks! I guess that leaves no other option than store standard size information in both - child & parent plugins. I was hoping there would be a workaround for it. Quote Link to comment
