Print to PDF
I am trying to print / export a PDF file.
I am using (full script Below)
AcquireExportPDFSettingsAndLocation
This launches a dialog window that I then have to manually set the file location and click okay...
I want all this automated, how?.
Is there a way to tell a Dialog what settings they are. If so is there a way to find out what the dialog settings are so I can tell them.
Anyone else have a method of exporting PDF or Image files that can be fully automated?.
Procedure ChangeThis1;
VAR
i: Integer;
Result: BOOLEAN;
Result2: BOOLEAN;
lName: String;
handleToLayer: Handle;
BEGIN;
Result:=AcquireExportPDFSettingsAndLocation(true);
Result2:=OpenPDFDocument('PDFOutput');
i:= ExportPDFPages('test');
ClosePDFDocument;
END;
Run (ChangeThis1);
