chadoli1 Posted March 22, 2010 Share Posted March 22, 2010 Is there a way to reset a label legend? For Example- I have a legend with the channel directly behind the light- then I move the channel (on a single lamp) to the left to get it out of the way of another unit- Is there a way to get the Channel to "snap" back to its original location later? Quote Link to comment
ericjames Posted March 22, 2010 Share Posted March 22, 2010 I believe (although, I have not tested it) that if you select the light and then choose "assign label legend" and choose the original legend then it will be restored. I hope that works/helps Quote Link to comment
ericjames Posted March 24, 2010 Share Posted March 24, 2010 I assume it worked then? Your welcome! Quote Link to comment
