Dom Smith Posted March 15, 2010 Share Posted March 15, 2010 Help! I've suddenly developed an apparent problem with VW2009 in getting it to render beams with gobos. It seems to have happened since I installed SP 5. I've been using VW for more than 5 years and understand the conditions required to get Renderworks to draw gobos and have checked that I'm meeting all the conditions required by the software: Gobos have been applied from the edit button for the fixtures (they're VL3K spots) using a gobo from the Rosco breakup range (although I've tried several others, including the defaults). The fixtures are on, in white @ 75%. They're pointing at valid focus positions. There are valid 3D objects in the layer for the gobo to render onto. The lit fog and cast shadows buttons are checked. I get no output from the light (no beam and definitely no gobo) using any of my usual Renderworks settings. I can get the fixtures to render the beams if I remove the gobo, but that's not what I'm after. Originally I thought I might have done something silly to the drawing, but have since tried re-starting the software and creating a new drawing with only one fixture and this doesn't work either. Anyone got any ideas what's happening? VW 2009 SP5 MacBook Pro Intel Core 2 2.33Ghz 2 GB Ram Quote Link to comment
Jeffrey436 Posted March 28, 2010 Share Posted March 28, 2010 I am having this same issue, I did all of the same things you described thinking I had made a slight rendering error, however I can not get the beams to render either. Has anyone solved this yet? Thanks Jeff VW2009 Macbook Pro Intel Core 2 Duo 2.8GHz Quote Link to comment
michaelk Posted March 28, 2010 Share Posted March 28, 2010 It has nothing to do w/ gobos. Some of the 2009 instrument symbols (especially the VLs) seem to be legacy units. If you move the instrument a few inches away from the truss or pipe it will instantly work. The problem is that the light is coming from the insertion point (ie the middle of the clamp / middle of the pipe), not the center of the instrument. So the pipe or truss is blocking the light. There are a couple easy fixes: 1. Give the lighting position a texture that doesn't cast a shadow. The Default Instrument Texture works. 2. Edit the 3D part of the symbol. Add a 3D locus in the middle of the body of the instrument. Most of the 2009 library works correctly. You happened to find a couple that don't. These all seem to have been fixed in 2010. hth michaelk Quote Link to comment
