Hello Community!
This Saturday, May 30, from 9am – 12pm EDT we will be performing maintenance on the Vectorworks Community Board. During this time, the site will be unavailable.
djnelson75
Worksheets
I am trying to get a handle on worksheets I have been able to create worksheets for predefined elements in vectorworks. Walls, Windows, Framing ect... This there a way to schedule Generic 3D objects. What I really what to schedule the lengths of some extudes I made.
There is no function to get the length of an extrude directly.
You can use (for simple extrudes) a formula of:
=CriteriaVolume/CriteriaArea
Set up the database criteria to be
Type is Extrude
You may also want to add additional criteria to specify only extrudes in a certain Layer or Class.
Put the formula above in the database header row for one of the cells and you will have your length. You can then add other formulas and format as necessary.
I am assuming that you know how to change a row to be a database and edit the criteria. If not, ask again.
Thanks for the reply, that worked great. I was able to get the lenghts of my extudes. Now I am questioning whether or not a going about my task in the most effiecent way being a new Vectorworks user. I Need to model and schedule some light gage hat channels and J profiles. Since I couldn't find anything like that standard vectorworks tools I was going to just use standard extrudes to model them and then schedule there lenghts through the worksheet. If you have any suggestions on a better way to model these elements I am all ears. Thanks
