Luffer Posted February 28, 2010 Share Posted February 28, 2010 (edited) I created a Rectangle and extruded it, the I subtracted another solid from it. Now I need to texture the top and sides, but the "Part" is greyed out, I can only add one texture all over. How can I get "Top" and "Side" parts back to my Solid Subtraction? Edited February 28, 2010 by Luffer Quote Link to comment
Pat Stanford Posted March 1, 2010 Share Posted March 1, 2010 If the solid you subtracted is a simple shape and planar with the extruded rectangle, you need to do do a Clip Surface of the objects before you do the extrusion. If it is a more complicated shape, the best you are going to be able to do is to convert the final object to a MESH and then Edit Group and pick the parts you want to texture. Quote Link to comment
