  • 4
Lock Proportions
Kevin McAllister
I would like the ability to lock/unlock an objects proportions in the Object Info Palette much like you can in Illustrator. This option should default on for imported images. Then you could enter an x dimension and have the y change in proportion. It would also be useful for all sorts of geometric objects, both 2D and 3D.
This functionality already exists for Image Props with the Lock Aspect Ratio checkbox.
KM
Edited by Kevin McAllister
Added tags
10 answers to this question
I'm going to bump this thread. Here's an example of some controls from the new forum :D that are similar to what I'd like in the OIP - a constrain proportions checkbox and dimensions that update in proportion when you type in one dimension and proportions are constrained.... (the search function in the new forum is amazing by the way!!)
Kevin
Comments about search function
