cameleyes Posted February 16, 2010 Share Posted February 16, 2010 Hi guys, Wondering if there is some bright spark that can help me out. As you can see from the attached image this is currently a very simple 2D demi-lune shaped piece of furniture. I need to split the face on elevation into a series of panels 136mm wide, no problem on the flat face, is there some way of accurately working this out for the arcs either end from the plan? Really appreciate any help on this. Matt Quote Link to comment
Ray Libby Posted February 16, 2010 Share Posted February 16, 2010 Arc Length is shown in the Object Info Palette under Arc Len: when the arc is selected. Quote Link to comment
barnes2000 Posted February 16, 2010 Share Posted February 16, 2010 Also, have you tried using Duplicate Along Path? Try taking your 136mm panel and then Shift select the arc and choose Duplicate Along Path. Quote Link to comment
cameleyes Posted February 18, 2010 Author Share Posted February 18, 2010 thanks guys for getting back to me Quote Link to comment
