cameleyes Posted February 16, 2010 Share Posted February 16, 2010 Hi guys, Wondering if there is some bright spark that can help me out. As you can see from the attached image this is currently a very simple 2D demi-lune shaped piece of furniture. I need to split the face on elevation into a series of panels 136mm wide, no problem on the flat face, is there some way of accurately working this out for the arcs either end from the plan? Really appreciate any help on this. Matt Quote Link to comment
islandmon Posted February 17, 2010 Share Posted February 17, 2010 Recall that Arc length is determined by multiplying the Radians of the angle x the radius of the arc. A 90? arc = 1.57079... rad times a R=100 , Arc Length = 157.079.. If you require Arc Lengths = 136 mm then say that you use 4 segments @ 22.5? 22.5? = (22.5 x 0.17453.. ) = 0.392699 rad 136 / 0.392699 = 346.32123 = Radius Quote Link to comment
cameleyes Posted February 18, 2010 Author Share Posted February 18, 2010 Many thanks for your help - very useful, although way beyond my comprehension of maths :-( Quote Link to comment
islandmon Posted February 18, 2010 Share Posted February 18, 2010 It's not so hard to understand..check out this tutorial: http://en.wikipedia.org/wiki/Radian Quote Link to comment
willofmaine Posted February 18, 2010 Share Posted February 18, 2010 Are the panels going around the curved ends flat or curved? It they're flat, simply draw a circle with a 136 mm radius centered on one end of the panel. Where that circle and the arc intersect will give you the other end of a 136 mm flat panel (the "chord" of the arc). If they're curved, simply select one of the arcs and type 136 (mm) into "Arc Len:" in the Object Info palette. Most likely you'll need to rotate the resulting arc to the correct position. The Object Info palette will give you the "sweep" angle, which you can use with the Duplicate Array tool to replicate your 136 mm panels around the arcs. Quote Link to comment
Benson Shaw Posted February 19, 2010 Share Posted February 19, 2010 Or Dupe Along a Path where object for duplication is the end profile of a slat (or the extruded slat from end view), and the arc is the path. Choose Tangent option. Center of slat will be placed on path. For center of face of slat on path, use the Offset tool to make a new arc offset by 1/2 of slat width. Use this new arc for the path. Delete it when finished. -B Quote Link to comment
willofmaine Posted February 19, 2010 Share Posted February 19, 2010 Wow, all these years, and I completely missed the Edit > Duplicate Along Path tool. I think the reason I missed it is because there's also a "Duplicate Along Path" tool in the "Basic" palette that, I just realized, seems to be significantly different in how it functions. I'd always assumed the two tools, having the same name, were the same tool.... silly me. Thanks B Shaw! Quote Link to comment
