J Hank Posted February 11, 2010 Share Posted February 11, 2010 I have a problem inserting a window into a wall in 2010. Never had this problem in 2009. I begin the action (via icon or Shift+D) and all looks fine for a second and then the mode icons switch back to the 2D Selection Tool and I am not able to insert a window! Anyone else have this issue? Quote Link to comment
mike m oz Posted February 12, 2010 Share Posted February 12, 2010 Do you have Wall Insertion Mode turned on? Do you have Class Options set to Show/Snap/Modify Others switched on? Quote Link to comment
J Hank Posted February 17, 2010 Author Share Posted February 17, 2010 So I'm just getting back to this issue. Thank you so much for your response. I did check the wall insertion mode is on and i have my settings as show/snap/modify others! If I click on the window icon itself, when i move my mouse a few inches away from the icon, everything switches back to the 2D Selection Tool as if I never clicked on the icon to begin with. I was able to hold my mouse near the mode icons, hit the shift+D to begin the window insert and click on preferences. When I did this I received an error message that says "An attempt to defina a Plug-In Object named 'Window' failed because Symbol Definition with that name already exists in the current document. The entire operation is cancelled."...so i went to my resource browser and chose a window symbol from there and tried to insert it but it shuts VW down. Hummm.... Quote Link to comment
Ozzie Posted February 17, 2010 Share Posted February 17, 2010 Create a signature with puter specs and VW version - My Stuff above Quote Link to comment
J Hank Posted February 17, 2010 Author Share Posted February 17, 2010 I'm not sure if this is everything I should have in my signature but here goes... Quote Link to comment
Pat Stanford Posted February 18, 2010 Share Posted February 18, 2010 You can only have a single object in a drawing with a specific name. If you have a symbol named "Window", the window plug-in won't work. If you have a symbol (or class, or just a named object) named Door (or any other PIO name), then that PIO won't work. Rename the symbol to Window-1 or something and your Window tool should work again. Quote Link to comment
