nevillem Posted February 9, 2010 Share Posted February 9, 2010 Is there a way to temporarily overide the graphic attributes of a class? For example whilst I am drawing thin dotted lines as set as the default attribute I then wish to draw thick solid lines for a while in the same class. The only way I can find to do this is to draw them all at the default settings then select them all and change them in the Object Info Palette. This is not very efficient - am I missing something? Quote Link to comment
willofmaine Posted February 9, 2010 Share Posted February 9, 2010 You need to edit the class and deselect "Use at Creation." Then the current graphic attributes set in the Attributes palette will apply to everything drawn in that class. With "Use at Creation" selected, everything drawn in a particular class is controlled by that class's attributes. Quote Link to comment
nevillem Posted February 10, 2010 Author Share Posted February 10, 2010 Many thanks for the prompt response - not so difficult when you know how ! Quote Link to comment
