Yoginathaswami Posted February 8, 2010 Share Posted February 8, 2010 Aloha, Is there a special trick to switch the active class with key command? I have my preferences set to use "command + arrow" keys to switch the active layer/class. The key command only works for layers but not for classes... I have all classes visible. Searched the forum didn't see any post from the past. Any idea why? Thanks in advance! Quote Link to comment
Benson Shaw Posted February 9, 2010 Share Posted February 9, 2010 This is from the VW help under Shortcuts: Cmd up/down arrow switches layers Cmd left/right arrow switches classes That what you mean? -B Quote Link to comment
michaelk Posted February 9, 2010 Share Posted February 9, 2010 I wonder if it is possible to change those in a custom workspace. You might try switching to one of the stock workspaces and see if you still have the problem. hth michaelk Quote Link to comment
Pat Stanford Posted February 9, 2010 Share Posted February 9, 2010 Not settable in the Workspace Editor, but in the VW Preferences. Check the Arrow Keys box in the Edit tab. Quote Link to comment
Yoginathaswami Posted February 9, 2010 Author Share Posted February 9, 2010 Pat: I have it setup in my VW pref.?command + arrow key. However, I just learned by accident a short while ago that: 1. Command + up or down arrow allows one to switch the active design layer 2. Command + left or right arrow allows one to switch the active class. Quote Link to comment
