Xander
Vectorworks 2008 on Windows 7 x64
Hello, I have a copy of Vectorworks 2008 and have been using it fine on my computer, but I just bought a new computer with Windows 7 x64 and now I am having some trouble. When I install VW2008 it goes through the whole thing and says it finished the installation successfully, but when I try to run VW2008, it can't even start the program without crashing. I saw in the common problems section that it doesn't like 64 bit processors, but Win7 has a pretty good 32 bit emulator. I guess my question is what is most likely the problem?
-Windows 7 itself
-64 bit processor
-QuickTime 7.6.5 instead of the old 7.2 or whatever that is recommended
Thank you for any assistance,
-Tim
5 answers to this question
I downgraded my QuickTime to 7.1.5, but that didn't fix it. I ended up running it in WinXP compatibility mode and it started and appears to be working...We'll see if this is a permanent solution and how slow this makes it.
Thanks,
-Tim
Guest jkelly
Did you try the vcredist solution as well?
hi, Have just done the same thing: new install of landmark 2008 on a 64bit system, checked quicktime installed vcredist files through the link and no luck.
It ran fine on a 32bit vista set up, now even when running it in xp compatability mode it crashes every time i touch the plant tool in a new file.
Old vwx files from previous projects appear to be immune to the crash problem i can select, add and move plants no problem its just in a new file.
Any help from the forum is much appreciated as i cant yet afford to upgrade so i need to resolve this!
thanks in advance
peter
Solved now, created a new template file from an old vw file from a previous install. Seems ok now running in win 7 normally no compatibility mode.
peter
