sicily80 Posted October 9, 2001 Share Posted October 9, 2001 Does anyone know how to set their own line weights in the attributes palette? It is preset to 1,6,12, etc. I'd like to preset it to my own preference. Thanks! Quote Link to comment
Matthew Giampapa Posted October 10, 2001 Share Posted October 10, 2001 Look in the "Page" menu and under "Set Attribute Defaults" --> "Line Thickness..." This command will let you change the line weights in the attribute panel for just this document. If you would like this setting for all documents, save an otherwise blank file as a template in your templates folder. This will add it to the list you see when you use the "New" command. If you leave the name as default the dialog prompts you with, it will become the default blank document when you choose just a plain blank document. (Wow, didn't think I could use document that many time in any post, Opps) Matthew Giampapa Technical Support quote: Originally posted by sicily80: Does anyone know how to set their own line weights in the attributes palette? It is preset to 1,6,12, etc. I'd like to preset it to my own preference. Thanks! Quote Link to comment
