Assembly Posted February 1, 2010 Share Posted February 1, 2010 This one i've been working on for a few, thought it might be useful to others. What the script does is loads a text file into an Array Searches the Array for BeginSym and EndSym Copys the text in between these calls into a new array. Then uses the array to write a new text file. In short It turns the Symbols into Procedures. HOW TO USE 1) Create a file with a number of symbols. 2) Export the text file as a script. 3) Name the file as per what this script looks for (look inside Procedure PlatformFileName). 4) Run this script and it will output a new file (again look inside Procedure PlatformFileName). 5) $Include the output file in a PIO. 5.1) Create a POP up and cut and paste the list you find in the output file. You now have a PIO with a pop up to select which symbol Procedure to draw. http://pastebin.com/mbf4d40d Quote Link to comment
