dcont Posted January 29, 2010 Share Posted January 29, 2010 Alright. I have read numerous post regarding walls acting funny in VW 2010. I have tried to get these walls to join but VW keeps on saying they do not intersect. I attached a file with a simple condition. Can anyone join these successfully without moving the walls over? What am I missing? Thanks in advance. Quote Link to comment
CipesDesign Posted January 29, 2010 Share Posted January 29, 2010 dcont, "think different". Try this: 1) use the Remove Wall Breaks tool to clean up all three wall ends; 2) select the top right (vert) wall and the middle horizontal wall and the hit command+J (join) then; 3) select the wall joint tool, in T mode, and touch the angled wall and then the vertical wall. See result in attached... Quote Link to comment
dcont Posted January 29, 2010 Author Share Posted January 29, 2010 Thanks Peter. I knew it would be something simple. It works fine in VW09 when trying to join the thinner wall first though. :confused: I think I understand why this is. Try this new file where the angle of the wall to be joined is hitting the exact corner. I still get the error message of wall not intersecting. Bug? Quote Link to comment
CipesDesign Posted January 29, 2010 Share Posted January 29, 2010 Could be a bug. My rule: if it doesn't behave "as expected" and if you can reproduce it, file it as a bug. Make sure to send a file and instructions... Quote Link to comment
dcont Posted January 29, 2010 Author Share Posted January 29, 2010 Submitted! Just needed a second opinion. Thanks again. Quote Link to comment
