3DTOPO Posted January 29, 2010 Share Posted January 29, 2010 Greetings, I have complex geometry defined in a preexisting DXF file that I need to somehow create a solid or surface from. I require solids/surfaces so I can eventually generate g-code tool paths that I can use to mill the surface on my CNC machine. I am a first time user of VW and I am using the an evaluation installation. Any advice would be greatly appreciated. Thank you. Quote Link to comment
Ray Libby Posted January 29, 2010 Share Posted January 29, 2010 Welcome to the forum. You can post a file here and it would make it easy to answer. Click on the Switch to Full Reply Screen link below and use File Manager to upload a simple file showing this. Quote Link to comment
3DTOPO Posted January 29, 2010 Author Share Posted January 29, 2010 Great, thank you Ray! The file is attached. Please let me know if you have any questions. Thanks again! Quote Link to comment
Ray Libby Posted January 29, 2010 Share Posted January 29, 2010 I'm not sure there is a whole lot you can do with this, it's thousands of 3D polygons. You can select all then Menu bar>Modify>Convert>Convert to Mesh. Would that do you any good? Quote Link to comment
starling75 Posted January 30, 2010 Share Posted January 30, 2010 Hi, does this help you? (Change the suffix of the file from vwx to zip. Unzip it and you will find cca 9Mb vwx file inside ...) Quote Link to comment
Ray Libby Posted January 30, 2010 Share Posted January 30, 2010 How did you convert it to a generic solid? Quote Link to comment
starling75 Posted January 30, 2010 Share Posted January 30, 2010 1)Convert smaller portions of the model (up to 1000 polygons) into meshes (Ctrl+alt+R). 2)Then convert these meshes into groups of NURBS surfaces (Ctrl+Alt+N) 3)Stitch and trim NURBS surfaces together (Ctrl+Alt+H) 4)Run solid addition 5)Convert the result into generic solid. Quote Link to comment
3DTOPO Posted January 31, 2010 Author Share Posted January 31, 2010 Thank you both Ray and Bohdan. I think your method did the trick Bohdan! I would have never guess that method in a million years. Thanks again. Quote Link to comment
