VW version 12.3.5 oval offset
Setting aside the when-is-it-an-oval-and-when-is-it-an-ellipse discussion for a second...
And ignoring the rotation issue... :)
I have noticed (in VW 2010) that the offset tool, when applied to the inside of an oval/ellipse, shrinks the semi-major axis slightly more than the offset value. The major axis shrinks the expected amount.
When applied to the outside of the oval, both the semi-major and major axes have the expected values.
That may be what you are seeing...
This might be one way to overcome: Temporarily rotate the oval horizontal, duplicate, enter the new height and width values in the OIP, rotate back...
michaelk
Well, setting aside when-it-is-an-oval-and--- discussion:
Still the problem remains when the offsettool is used on a rotated oval, i will not get a smaller rotated oval but a polyline (some are bezier, some are spline based) with a wierd shape.
So why is this? And using values is nice, but needs calculation....
Anyone from Nemetschek??
Robert
