lucylou Posted January 21, 2010 Share Posted January 21, 2010 Hi Ive been having some problems since the big switch over to VW2010 and have reported some on here, however they dont seem to be resolved. Main things are all/a lot of walls moving when you move one, and straight lines dont look straight. Haven't upgraded to SP2 yet, and wondered if anyone else has experienced these problems, and if so, are they resolved in SP2? I know there was a thread about the walls moving. Many thanks Quote Link to comment
MBMD Posted January 21, 2010 Share Posted January 21, 2010 I have the same problems with 2010 and SP2. The walls being attached to each other and moving together is a big issue the needs to be fixed. Turning off the auto connected wall mode helps some but then you have to clean up all the walls manually. I've also had a problem with associate dimensions preventing objects from being moved. Quote Link to comment
lucylou Posted January 21, 2010 Author Share Posted January 21, 2010 Thanks for that info MBMD, shame they havent bothered to sort it for SP2. I have found that if you close VW down and re-open it then it goes away, but it is very time consuming and yet another example of a way VW is failing miserably in... time effectiveness! any news VW people on when it will be sorted? Quote Link to comment
jeffroyer Posted January 28, 2010 Share Posted January 28, 2010 Same problem here. Zoom in to do some wall joins, zoom out and discover that some random wall has moved. REALLY causes problems when you are dealing with existing conditions and those walls need to stay put! Quote Link to comment
colin smart Posted February 23, 2010 Share Posted February 23, 2010 This is anightmare when doing construction plans and is DANGEROUS for Architects - walls do move by themselves when you have zoomed in close and this could be missed and dr4awings issued to site. When are Nemetschek going to sort this serious bug? Quote Link to comment
Jeffrey W Ouellette Posted February 23, 2010 Share Posted February 23, 2010 Et al, Have these issues, and the files in which they are occurring, been submitted for review and investigation via Bug Submit? This board is NOT an official technical support or bug reporting resource. That is why we have links to those resources at the upper right. If you want a resolution to the problem, then you have to give the engineering staff the evidence of the problem so it can be analyzed and fixed. I, personally, have NOT seen this issue in the work I have been doing with Vw2010 since the last couple betas before release. Quote Link to comment
Bob Holtzmann Posted February 24, 2010 Share Posted February 24, 2010 Try Locking the walls. I've had similar problems with the floor moving, but that was my doing. And locking it helped. I've learned that a casual click of the mouse can move unaccounted for objects in Vw -- that's why I like to set editing to the Current Class Only to limit the damage. Quote Link to comment
