Window ID Class always changes
Sky
Every time I edit the window, it changes the Window ID class. I have to manually set it to Window-Spec every single time.
Not only that, there are two Window-Spec listed in the pull down menu even though when I edit the classes, there is only one listed.
This is driving me crazy. What am I doing wrong?
Sky
Hi Sky,
Upon further examination, I can duplicate your issue by creating the Class Window-Spec manually, then if I go to the Window Settings dialog box and check the "On Schedule" box, then go to the pull-down there WILL BE two selections called Window-Spec. It seems however, that no matter which one of the Window-Spec classes you choose, your data WILL appear on the Window Schedule.
I'll submit a report/bug to our engineers
Thank you for pointing this out
Wes
I am running VectorWorks Architect with Renderworks 2010 SP2 on an early 2009 Mac mini.
So, my biggest problem is that I have to manually change the Window ID back to Window-Spec every time I change the settings for a window. When I open the Settings dialogue box for any window, it will show the Window-ID set to either Ceiling-Fixtures or Ceiling-Main or ----------------, which I don't even know what that last class is. If I don't change it back to Window-Spec, it will disappear (because the class it sets it to invariably is hidden).
I don't have the problem with my door settings.
This occurs in multiple project files.
I upgraded from 2008 a couple of months ago, but I don't know if that is related to the problem. It happens whether or not the window was an old window created in the 2008 file or if it is a new window created while running 2010.
The smaller issue is having 2 Window-Spec classes listed in the pull down menu in Window Settings. I just thought the problems might be related. However, it is interesting that there is only ONE Window-Spec class listed in all other listing of classes everywhere else in the program. I have not manually created a second class with the same name.
Hi Sky,
I think you're right...
I'll report it as a bug.
Thanks for pointing it out
BTW, Ceiling-Main and Sills are classes created by VW for use mainly when creating Reflected Ceiling Plans. Ceiling-Main creates two parallel lines at the window or door head so your drawing will read correctly in RCP and Sills controls the door swing, also so your drawing will read correctly in RCP.
Wes
Edited by Wes Gardner
Hi Sky,
Yes, I can get the double entry for Window-Spec to appear in the Window Settings dialog box...see attached image.
I've reported it as a bug, as you stated, it's confusing and needs to be rectified - the good news is that the window schedule will still respond to the data regardless of which one you choose...
Thanks again for pointing this out
Wes
  • 2 years later...
