Daryl Wood 0 Posted December 17, 2009 What is the best way to adjust the highlighted wall face to plane with the adjacent perpendicular wall, in 3D? Regards, Quote Share this post Link to post
michaelk 533 Posted December 17, 2009 3D Reshape tool. Assuming you have VW2010.... (It might also work for 2009) Double click the wall (or select the wall and then the 3D Reshape Tool) Make sure you are in the Reshape 3D Walls Mode Grab the handle at the bottom of the face you want to move. Acquire the smart point on the top of the intersecting wall. (Holding down the shift key at this point helps) follow the plane and smart point cues to move the bottom handle into place. Repeat for the top handle. I think it works better if you move the bottom handle first. hth michaelk Quote Share this post Link to post
Daryl Wood 0 Posted December 18, 2009 Thank you Michael, it seems to work ok in 2009. Regards, Quote Share this post Link to post
