Are complex line types finally available in VW2010?
higgins
Higgins the answer is unfortunately no. Its been asked for often, but the answer always given is to use the Repetitive Unit tool with an appropriate symbol. That mostly works okay though you may have to fiddle with the symbol pitch (ie. spacing) to fix up misalignments at vertex points.
The ability to import and export true complex line types would be very useful.
Especially to because the old Duplicate Along Path Tool - not the one from the Edit/Duplicate Along Path - the one that you had to add to your Workspace - does not work in Rotate Plan when you use Create Path
The Edit/Duplicate Along Path only uses an already created path
It is a shame to see a tool like this go backwards and I cannot believe other users have not noticed this
