Jules2009 Posted December 14, 2009 Share Posted December 14, 2009 The walls in my house have disappeared. It was there to start off with then after i stuffed around a bit it went. The windows are there and i can see the bottom of the walls but nothing else. I have class style selected in the attribute pallete and a texture selected for that class. Help please!!! Quote Link to comment
mike m oz Posted December 14, 2009 Share Posted December 14, 2009 You probably have the option for Link Wall Heights to Delta Z switched on. Select a wall and look on the OIP (Object Info Pallette). If it is on uncheckmark it and you will then be able to set the Wall's Delta Z and Bottom Z on the OIP so you walls start and finish at the required heights.. Quote Link to comment
Jules2009 Posted December 14, 2009 Author Share Posted December 14, 2009 Thats exactly what was, thanks Mike! Quote Link to comment
