Section viewport bug or what?
Are Section Viewports just another useless ?feature? which does not actually work?
In some section viewports, even in the same file, not all sectioned objects are interpreted correctly. Moreover, various Advanced Properties have very odd consequences: Merged Cross-sections may fix some problems, but not necessarily all. Some sections behave as expected, some badly.
Detected in VW 2009; in VW 2010 the situation is even worse? A lot worse!
(Hard to explain, I'm afraid.)
I've often encountered this with section viewports. In the end of drawn over the offending bits in the viewport annotations, which is a terrible work around.
I have experimented a bit and I think some of these problems occur when sectioned objects are grouped in one or more layers of grouping (ie. a group within a group). This "grouping" issue affects some rendering modes as well, displaying extra lines etc.. I've never reported it as a bug because its very random and hard to isolate.
Kevin
